protocol217
I have an electric skateboard that is controlled with a handheld remote controller that looks like this:
It is powered from a 9V battery. and from the side it has like piece of aluminum foil that serves as antenna i think.
The receiver on the skateboard looks like this:
the blue wire (J1) is the antenna i have tried many antennas for WiFi, Bluetooth 3G/4G, best range is with the original antenna ( the isolated red wire on the picture), but the problem is that the range is 60 cm maximum and the signal sometimes cuts out when i am driving and that's very annoying.
i have also tried adjusting a Little those pots but it makes it only worse also on the transmitter, so i returned everything to original settings.
And i tried boosting a voltage on the transmitter from 9 to 11V but that also does not help.
And last i connected the antenna of the transmitter to the antenna of the receiver with copper wire and that extends the range as much as the wire is long but i don't want to have a wire attached to my skateboard a want it to be wireless RF controlled.
What should i do to get a little more range out of this remote at least 1 meter?
