RickyZA
Hi there everyone,
Im looking for a replacement transistor for a logic board, unfortunately there was a short and it blew out the transistor, the short has been resolved though. Here is the damage. Q8002
Board Model : EAX61682903
Original Transistor Datasheet : http://pdf.datasheetcatalog.com/dat...ctronics-corporation/RT1P141C_to_RT1P141U.pdf Marked P1
No input voltage stated on first link although this one says -40v , http://www.idc-com.co.jp/search/search/Pdf/en/6/RT1P141U , my alternative DDTA114 states +10 to -40v , the PDTA114 however states only +40v, otherwise the PDTA114 is actually very very similar although im not sure if this was a typing error.
Links : DDTA114 http://pdf1.alldatasheet.com/datasheet-pdf/view/178572/DIODES/DDTA114ECA-7-F.html
PDTA114 - http://www.farnell.com/datasheets/1511866.pdf
Main Board Schematic for transistor Reference: http://www.manualslib.com/manual/1196638/Lg-32le5500.html Not the exact same model but im pretty sure they use the same transistors marked P1 which is the RT1P141C and marked exactly the same on the board as Q8002. I can also see the P marking on the transistor all though the 1 marking is burnt out.
Thank you
Thank you
