rs14smith
Alright so what I am doing is getting reed of any components that I do not need to make the smaller in size. I already hooked up the board, installed my program and it works as I need, but I also have many other things on the board that I am not using so I want to get reed of them.
These are the components/pins I do not need:
-Battery Port (located on far left side by edge)
-Charging Port (located on far left side by edge)
-Reset Button (located on far right side by edge)
-Reset LED (located on far right side by edge)
-pins A0-A7 on ATMEGA... chip
-pins D6-D13 on ATMEGA... chip
So I deleted those components on the schematic, however, I am not sure if I deleted something that was needed for the Arduino to still function.
I'm mostly worried about the PC6(/RESET) which I deleted the S1 switch for.
I have attached the modified schematic (has less parts), then the original schematic respectively.
Thanks![Stick Out Tongue :p :p](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
