Need help connecting a spectrum analyzer to a breadboard
aries
Please can anyone tell me how to connected the bread board to spectrum analyzer. I have made a circuit of low pass filter on bread board and i want to see the frequency response on spectrum analyzer. what do i have to do? i have a cable whose one end is connected to the spectrum anlyzer input and second end is a BNC. what to i have to do to connect to a single wire coming from bread board to sectrum analyzer?
A spectrum analyser on its own will not show the frequency response of a filter.
To show the frequency response, the analyser must be used in conjunction with a tracking generator.
What sort of filter is this?
An audio filter or an RF filter?
@JimB
It is an RF filter. I do not have a tracking generator. Without tracking generator It means I cant see the frequency response on spectrum analyzer?
Please guide me how to connect a single wire comming from a simple breadboard to spectrum analyzer without Tracking generator?
Is it necessary to connect tracking generator.?
If I have a spectrum analyzer with builtin tracking generator than how can i connect a single wire comming from breadboard to signal generator
You don't have a single wire from the filter, you have two wires, the signal and ground/chassis - exactly as you would with an oscilloscope.
I wouldn't have thought you would need a tracking generator woith a spectrum analyser, just a white noise source.
@nigel
Exactly 2 wires are comming out. one ground and outher is the output wire. oscilloscope will show in time tomain. I want to see the frequency response of low pass filter. how can i see?
I am giving input from frequency generator to the filter circuit and output should be connected to the spectrum analyzer. The problem is i have one cable its one end is connected to the spectrum analyzer and second end of the cable is a BNC (MALE) now how can i connect to breadboard.
A piece of screened cable with a female BNC on it - or a scope probe direct from the spectrum analyser.
However, a frequency generator won't give you the frequency response with a spectrum analyser.
how can i then give the input to my filter circuit as i want to give a 500mV signal to the circuit. u were talking about white noise generator ?? Is this a signal generator??
Kind of, it generates ALL frequencies at the same time, which is called white noise, the spectrum analyser will display which ones get through, giving you the frequency plot you want.
To do it with a signal generator use a scope instead of a spectrum analyser, and manually measure the output at each individual frequency and then manually plot a graph.
Quite correct, I had initially thought of mentioning a noise source, but decided to keep it simple.
However, the frequency spectrum of the noise may not be flat across the frequency range of interest.
It is necessary to compare the noise in and the noise out from the device under test if you are going to go down this route.
please tell me from where should i give the noise source cant i give the input to thelow pass filter from frequency generator.
@jimB
I have just got a spectrum analyzer. a probe whose one end is connected to the spectrum analyzer and the other end of the probe is a BNC(male).
low pass filter which is implemented on breadboard has two wires one for ground and other is the output wire. now how the BNC (male) connector be connected to the output wire comming from breadboard.
from where do i have to get the white noise signal to give to the input of filter?
I only have function generator and frequency counter?
I want to give 500mV signal to the filter input
@jimB
You will need a panel mounted female BNC connector, solder a wire to the centre pin for the signal and the use a screw and nut to fix a wire to the BNC connector case, for 0V.
Does your spectrum analyser have a white noise output.?
hi aries
Ref our Chat.
What information do want to know about your 1MHz low pass filter.?
Do you want to plot the response ?
yes ericgibbs i want to plot the frequency response and i m using a spectrum analyzer to see the response. still i have confussion in giving input to the lowpass filter having cutoff frequency 1MHz. and connecting the filter output to the spectrum analyzer.
Any alternate available for seeing the response?
No spectrum analyzer does not have a white noise output m using IFR 2395 model spectrum analyzer. I am using spectrum analyzer for the first time so dont have any idea
Do you have a dual channel oscilloscope.? and a sine wave signal generator that will work upto 1.5MHz
https://en.wikipedia.org/wiki/Low-pass_filter
EDIT:
Look thru this pdf.
  • active_filters.pdf
@ericgibbs
Yes i do have a dual channel oscilloscope and a function generator having frequency upto 5 MHz.
but the oscilloscope is in time domain. For frequency response the x-axis is a log frequency scale.
@ericgibbs
You can still plot the frequency response of the LPF using the scope and sine wave generator, in the way I explained on chat.
The 6db point on the Bode plot will be when the output voltage is half the input voltage, the just read off the frequency from generator scale.
Can you post a digram of your low pass filter.?
