Need Help Deciphering Circuit Board Schematic
TBennettcc
Hello.
My name is Tim. I am a recent graduate from Florida Gulf Coast University with a Bachelor's Degree in Computer Science. However, I am not so experienced in circuit design, even something fairly simple.
I was recently given a MIG welder by a friend (Craftsman, re-branded Century 90GL). He claims the wire speed control never worked, and decided to try to repair it himself. It still doesn't work, so I decided to take a look at it. The wire speed DC motor is constantly receiving about 20 volts, regardless of the state of the switch on the nozzle handle. I checked the switch with an ohm meter. The switch works fine. I even disconnected the switch from the circuit board. The motor is still going. By looking at the physical circuit board, I have come up with the following schematic in EAGLE CAD, which I believe to be 99% accurate. My friend replaced two components, one was in a TO-220 package, and the other was in a TO-92 package. At this time, he is unable to find the components he removed from the board, so it is anybody's guess as to what they were. The components that are in the circuit now are an LM7812C voltage regulator (the TO-220 package) and an MPF 102 601 N-channel RF amplifier (the TO-92 package). (In the schematic, I replaced both with standard NPN transistors. I have no idea if that makes any sense...). There are also two "black and silver" diodes on the board, and two "black and orange" diodes on the board. They are labeled as such on the schematic.
That is the reason I'm posting. I need help deciphering this schematic, because it doesn't make any sense to me. For instance, the welder is DC only, no AC side. So the line voltage comes into the welder, goes to the power switch, through a transformer, and then through the power diodes. The wire speed control circuit board is then connected here, to this rectified power. So why is there a rectifier on the circuit board? Also, there are diodes towards the bottom of the schematic, which point up (i.e., allow flow from neg -> pos, but not pos -> neg (unless they're Zener diodes... I'm not sure)).
I will include everything I have from the manufacturer, the schematic and other EAGLE CAD files I have, as well as pictures of the actual circuit board. I need help to make sense as to how this thing is supposed to work. The voltage coming into the board is approximately 18.7 - 36.3 volts, and the voltage going to the DC motor is approximately 7.1 - 20.6 volts.
Any and all help is greatly appreciated.
Thank you for your time.
  • Welder_schematic.zip
