Need help designing a laser trip alarm receiver.
ItsMike
Hey guys,
I'm trying to make a laser trip alarm but i'm having problems designing the receiver.
I want to ASK modulate (with constant '1') the laser beam on some frequency so the receiver's input signal should look like a "clock" signal when the beam hits the sensor and obviously nothing when it doesn't hit the sensor.
I though of using a notch pass filter on that frequency but I'm thinking there must be some better way.
I was thinking of using an oscillator on the receiver and sampling the input signal with it, but what happens if the frequency isn't dead even ?
How do all those IR receivers do it ?
Thanks in advance,
Whats the distance of light path.?
I don't know, I think at least 25 meters.
Why is that relevant btw ?
I want to break the light with mirrors though, so the actual distance between receiver and transmitter is about 5 meters (I already though of using same clock for both circuits).
BUMP, anyone knows ?
Why not modulate the IR laser with say 38KHz or 40KHz and use an off the shelf TSOP receiver.
I cannot see why you think you need a clock for simple beam break detect.??
  • TSOP34838.pdf
I couldn't find an IR Laser anywhere, so I thought I'd use a plain red one.
I wanted to modulate it so random light won't trigger the receiver sensor.
