Richandmaria
I have designed many processor based projects (RF and standalone controller) , but I need help with this one as I no very little about chemistry and I believe this has to be known to do this.
Measuring Pool PH is easy as I have found many Circuits that do this electronically. Measuring the level of Chlorine in a pool seems to be always done using a comparison method ( pool tester with chemicals) I have not found an inexpensive “electronic” method. I am willing to give up some accuracy as this will be used as a early warning system. As my project is to place this device in the pool water, Battery life will be an issue as well, but those things I know I can solve.
Thus in a nut shell I would like information on a circuit that converts the Pool chlorine amount to a electronic voltage.
Any information on this will help.
