need help on first circuit. include a LDR and a Battery Charger (9V)
Dentsu
hi, i have this schematic but i need it to work. the LDR only goes on when there is little to no light and its only function is to turn an IR LED on/off. if it is not connected to main source (12v) the 9v battery kick in like how a battery backup work. once it is connected back to the 12v the battery can begin charging again and the main load can power off of it. please refer to this diagram below as i think the final schematic will look something similar. hopefully i am using the gate right and is what i am looking for. i am really new at this but i know enough to follow a schematic. **broken link removed**
it is gonna be connected to ground. is there anything else? and can anyone explain what is the difference in transistor? some of them just have many different code from say BC547BP and BC549BP. is that just manufacturer number and no technical difference?
here is a updated schematic and any comment and feedback would be appreciated. the function is still the same and i had help on another forum.
o open S3 with S1 closed and battery will run circuit
o open S1 with S3 closed and adapter will run circuit
o Both S1 and S3 closed will be automatic operation, Adapter keeps battery charged and load will be on When dark enough LED's will also be on.
