samuel.sam77
Hi
Any one plz help me on this code
5 led output (for delay status)
2 switch i/p
1 relay output
5 led status( 5min, 10min, 15 min 30 min, 60 min) delay
one switch for select delay and another switch for on/off (relay)
problem is on/off function not working properly ,some times working some times not
can anyone help me simplest way or bugs
#byte portc=0x07
#byte trisc=0x87
#bit start=0x05.0
#bit sel=0x05.1
#bit Rly=0x07.5
int8 minn,secc,msec;
int i;
#int_timer1 // timer code
timer1_isr()
msec++;
if(msec==8)
msec=0;
secc++;
if(secc==56)
secc=0;
minn++;
if(minn==59)
minn=0;
void main()
SET_TRIS_A( 0x03 );
SET_TRIS_c( 0x00 );
Portc=0;
i=0;
setup_timer_1(T1_INTERNAL|T1_DIV_BY_2);
enable_interrupts(INT_TIMER1);
enable_interrupts(GLOBAL);
msec=Secc=minn=0;
while(TRUE)
if(i==0)
output_high(PIN_C0);
output_low(PIN_C1);
output_low(PIN_C2);
output_low(PIN_C3);
output_low(PIN_C4);
if(!input(Pin_A1)) // delay selection loop
delay_ms(250);
i++;
delay_ms(10);
if(i==1)
output_low(PIN_C0);
output_high(PIN_C1);
output_low(PIN_C2);
output_low(PIN_C3);
output_low(PIN_C4);
if(i==2)
output_low(PIN_C0);
output_low(PIN_C1);
output_high(PIN_C2);
output_low(PIN_C3);
output_low(PIN_C4);
if(i==3)
output_low(PIN_C0);
output_low(PIN_C1);
output_low(PIN_C2);
output_high(PIN_C3);
output_low(PIN_C4);
if(i==4)
output_low(PIN_C0);
output_low(PIN_C1);
output_low(PIN_C2);
output_low(PIN_C3);
output_high(PIN_C4);
if(i>4)
i=0;
if(!input(Pin_A0)) // ON/off loop
delay_ms(50);
Secc=minn=0;
while(1)
if(i==0)
rly=1;
if((minn==5)||(!input(pin_A0)))
rly=0;
delay_ms(150);
break;
else if(i==1)
rly=1;
if((minn==10)||(!input(pin_A0)))
rly=0;
delay_ms(150);
break;
else if(i==2)
rly=1;
if((minn==15)||(!input(pin_A0)))
rly=0;
delay_ms(150);
break;
else if(i==3)
rly=1;
if((minn==30)||(!input(pin_A0)))
rly=0;
delay_ms(150);
break;
else if(i==4)
rly=1;
if((minn==59)||(!input(pin_A0)))
rly=0;
delay_ms(150);
break;
2 switch i/p
1 relay output
#byte portc=0x07
#byte trisc=0x87
#bit start=0x05.0
#bit sel=0x05.1
#bit Rly=0x07.5
int i;
timer1_isr()
msec++;
if(msec==8)
msec=0;
secc++;
if(secc==56)
secc=0;
minn++;
if(minn==59)
minn=0;
void main()
SET_TRIS_A( 0x03 );
SET_TRIS_c( 0x00 );
Portc=0;
i=0;
msec=Secc=minn=0;
while(TRUE)
if(i==0)
output_low(PIN_C1);
output_low(PIN_C2);
output_low(PIN_C3);
output_low(PIN_C4);
delay_ms(250);
i++;
delay_ms(10);
if(i==1)
output_low(PIN_C0);
output_low(PIN_C2);
output_low(PIN_C3);
output_low(PIN_C4);
if(i==2)
output_low(PIN_C0);
output_low(PIN_C1);
output_low(PIN_C3);
output_low(PIN_C4);
if(i==3)
output_low(PIN_C0);
output_low(PIN_C1);
output_low(PIN_C2);
output_low(PIN_C4);
if(i==4)
output_low(PIN_C0);
output_low(PIN_C1);
output_low(PIN_C2);
output_low(PIN_C3);
if(i>4)
i=0;
delay_ms(50);
Secc=minn=0;
while(1)
if(i==0)
rly=1;
rly=0;
delay_ms(150);
break;
else if(i==1)
rly=1;
rly=0;
delay_ms(150);
break;
else if(i==2)
rly=1;
rly=0;
delay_ms(150);
break;
else if(i==3)
rly=1;
rly=0;
delay_ms(150);
break;
else if(i==4)
rly=1;
rly=0;
delay_ms(150);
break;
