need help please
MLOTZ
hi looks like my programming skills isn't so good. I'm sending a signal at 9600 bps to my pic16f628a RB2(RX) PIN. BUT FOR SOME REASON DOES THE PIC NOT UPDATING THE "RCREN" REGISTER.
IF POSSIBLE CAN SOMEBODY TELL ME WHERE TO GET A EXAMPLE PROGRAM TO SEE WHERE MY PROBLEM MIGHT BE?
Please post your PIC coding.
Do you mean RCREG ?
LIST P=16F628A, R=DEC ; Use the PIC16F628A and decimal system
processor 16F628A
#include <P16F628A.INC> ; Include header file
S_IN EQU 0X20
INIT BSF STATUS,RP0
MOVLW 0X00
MOVWF TRISA
MOVLW B'00000110'
MOVWF TRISB
;MOVLW 0X0F
;MOVWF 0X92 ;PR2
MOVLW 0X07
MOVWF CMCON
MOVLW B'00100110'
MOVWF PIE1 ;PIE1
MOVLW 0X80
MOVWF INTCON
; SET BAUD RATE TO COMMUNICATE WITH PC
; Boot Baud Rate = 9600, No Parity, 1 Stop Bit
movlw 0x19 ; 0x19=9600 bps (0x0C=19200 bps)
movwf SPBRG
movlw b'10100110' ; brgh = high (2)
movwf TXSTA ; enable Async Transmission, set brgh
bcf STATUS,RP0 ; RAM PAGE 0
movlw b'10010100' ; enable Async Reception
movwf RCSTA
MOVLW 0X0F
MOVWF T2CON
; RECEIVE CHARACTER FROM RS232 AND STORE IN W
; This routine does not return until a character is received.
receive btfss PIR1,RCIF ; (5) check for received data
goto receive
movf RCREG,W ; save received data in W
START MOVWF S_IN
MOVF S_IN,W
MOVWF PORTA
END
hi mlotz,
Check why you have the UART RX interrupt enabled, when you polling, also where ISR ?
I Know My Program Is Half, But I'm Batteling With That Rcreg Why Isn't It Working. Don't You Have A Example That I Can Compare?
hi mlotz,
When you say your program is Half, do you mean you have only posted half the program listing?.
Check why you have the UART RX interrupt enabled, when you are polling RX, also where is the ISR ?
Have you looked at the datasheet regarding Interrupts?
hi ok I've disabled all my interrupts.
Will my program work without ISR?
I'm simulating it in pic simulator IDE,but for some reason the data that I'm sending to RB2 is not updated in my RCREG register.
Will you look at my program again PLEASE
processor 16F628A
S_IN EQU 0X20
org 0x00
start BSF STATUS,RP0 ; RAM PAGE 1
MOVLW 0X00
MOVWF TRISA
MOVLW B'00000110' ;set RB2,RB3 as inputs
MOVWF TRISB
MOVLW 0X07 ;switch comparators off
MOVWF CMCON
movwf SPBRG
movlw b'00100100' ; brgh = high (2)
BCF STATUS,RP0 ; RAM PAGE 0
movlw b'10010000' ; enable Async Reception
movwf RCSTA
MOVF RCREG,W
goto receive
MOVWF S_IN ;SENDING DATA OUT ON PORTA
MOVF S_IN,W
MOVWF PORTA
END
A ISR is an 'Interrupt Service Routine'.
If you have no interrupts enabled, you don't need an ISR.
I'll have another look at coding
hi mlotz,
If you add 'goto receive' just before the END statement, [so it keeps repeat testing RX] it works OK in my PIC sim.
i think i found my problem in my simulation I'm using the software UART simulator interface and not the hardware UART simulator interface.
After 3 days of battling with this problem and my program was ok!!!!!!
I need a drink.
Thanks for everybody's help.
I'm off to the BAR.
This is why it always pays to double check EVERYTHING.
