Hello,
I ordered a product from Europe that involves a coil heater. Unfortunately, it came with a European type power supply. I bought an adapter so I could plug it into US outlets, but I don't think it is getting hot enough. The instructions state that the heater should be powered with 12V, but I am not sure if AC or DC. Are coil heaters always powered by AC? Here is what the included power supply says:
PRI: 230V - 50Hz 70VA
SEC: 12V - MAX 60VA
I attached a multimeter to the power supply, and when I put it on AC it read about 6 volts. On DC it does not really move. So I think the power supply isn't outputting enough because it is expecting European voltages in. Does this sound right? So what I need is a US power supply that outputs 12V AC? That is what I think but I wanted to check with people more knowledgeable than I. Thanks a lot.
SEC: 12V - MAX 60VA
