GooseElectro
I want to make a device that will be able to control the volume, balance and on.off/ mute. Of several inputs and output I also want a main volume control. I also want to have a way of having two different things playing through two different outputs ( sort of sent output , maybe using two main channels. Basically complete control! ALL IN STEREO and all digitaly ie I can encorperate a remote ( I could do all this with manual controls ie a pot for a volume and switch for mute. I need it digitaly controled)
I have started somthing in the past, using a digital volume control chip controlrd by a PIC chip. However they are quite expencive and having a 16 pin ic for every volume control would prove to be very large and maybe over complicated. I was thinking that as I require alot of functions and control this maybe best done on a more digital bassis using adc and dac s ? Or is there some sort of audio processor that I can use ? Please help which is the best way? Are here more ways? All sugestions welcome ! Thank you
