biboymusic
I've been building Vaping Mods using 555 timer (PWM) driving a mosfet. It works like charm, very powerful and very decent battery life.
The schematic above is so good it can handle upto 200watts of power. All good.
However, I wanted to move up my project a bit, using a Digispark. Knowing it got hardware PWM, very small size and very low power consumption, it really fits the bill. Since most box mods run on dual 18650, I power the digispark through the Vin (accepts upto 12V). I've added wonderful functions like, prolonged firing protection, 3 clicks to lock etc. Tested it, all good but later realized at very high load like a 0.20Ohms coil, the Digispark halts and stops working. It won't fire, you need to remove the battery and power it up again. The 555 schematic above didn't have this issue.
Can someone help me on this? I'm suspecting that the linear regulator of the Digispark can't handle the Voltage dive when firing hi loads, which is non-existing using the 555 PWM version.
Thank you so much.
P.S. My friend ericgibbs maybe you could shed me some light on this. Thanks.
![PWM-555.jpg PWM-555.jpg](https://www.electro-tech-online.com/data/attachments/99/99614-9a4b8f415f875bea0186c66a2688125c.jpg)
Thank you so much.
