hi
i have PCWHD compiler. I need guideline how i can write the source code or the C code for PIC 16F778A and generate the code to hex code so that i could use for simulation in Proteus. thank you
You can edit programs with a text editor then use the compiler from a command line to generate the hex.
Most of us use an IDE Integrated Development Environment. CCS has one but you can also use the CCS compilers with MPLAB. For use with MPLAB you have to run a program that integrates the compiler with MPLAB.
You have to start reading the documentation. It will be nearly impossible if you don't.
