need help with transistor for driver
goodpickles
I need help decideing what transistor I should use to drive a relay. I have a photo cell the resistance on the OFF of state is 1K and on the ON state is 490ohms. My relay is 12 volts...on testing it kicks in at 6 volts and out at 2.
I have tried an LM3904 but at 12V that let about 2.3 volts leak threw.
Should i try a fet transistor.
I also have a moterola 8844 would that one work.
try an 2n2222a transistor.
The circuit suggested by Screech is crude as it does not have a threshold nor any hystersis. So you need a Schmitt Trigger between the photo resistor and the transistor.
If you use a LM311, you would not need a transistor since it has adequate internal drive capability.
You also said "I have tried a LM3904 but at 12V that let about 2.3 volts leak through"
It is impossible to comment on this without a circuit to look at. If you post one, I'll be happy to help.
Len
