I have a wire for a car audio accessory, now currently the product being installed is pushing 300mA and I need to make some sort of board (or something!) to convert that 300mA to 1amp. Is there a quick easy way of doing this?
Thanks..
Use a simple transformer that will lower your voltage.
You need a relay. Connect the coil to the 300 mA output and use the relay contacts to switch the 1A load.
