I want to split 2 independent PWM signals into 4 independent PWM signals.
The ideal IC would have 2 PWM inputs, 1 selector bit, 4 PWM outputs (2 ports of 2 PWM outputs), and a latch that maintains the previously commanded output whenever a pair of outputs (port) is not selected.
Does such an IC exist? I know I could do it with a PIC or something similar, but I would rather not if something already exists.
I found this: https://www.electro-tech-online.com/custompdfs/2009/12/tlc5940.pdf
but that uses a single serial input, and that will not be fast enough for my application.
Also: https://www.electro-tech-online.com/custompdfs/2009/12/tlc5904.pdf
but I believe this takes an 8-bit digital in, and I do not have enough free GPIOs to do that.
Any suggestions?
Any suggestions?
