need part name
MrDEB
looking for a part that I have seen used before. It plugs into a dip socket and you solder parts onto the terminals sticking up from part.
Want to use as a jumper over 2 supply traces.
instead of 8 wire jumpers this would be neater and cleaner than 8 seperate wires.
If I knew what to call it then I could find a picture of it.
I could maybe draw one.
If we look in the connectors chapter of RS Components catalog and specifically in production line items, DEB may find what he may be looking for.
However now a days no one is using such items.sometimes in 1980 to 95 they were used in communication equipments. It is aimed at frequently soldering locations in order to prevent PCB damage. Even a berg pin stick can be used for the same purpose, by cutting additional lead length.
P S: Yes , it is called component header. these are under RS Component Stock Nos 402-658,-664,-670,-686,-692 for 14,16,20,24 and 40 pins respectively.
