Need some help finding schematics please
Intheshed
Hi, Im looking for schematics for a Chicago electric - 2000 Watt / 4000 Watt
Peak Power inverter part number 95596 from harbor freight. i did search there
site with no luck, and i could use it asap. Or if you some advice about how I
should go about repairing it, that would be great. It simply will not power
on. TY in advance for your help
Google for homemade power inverters. You will see schematics for others and they all work about they same. That will get you started. If you have no power, you can start there and work your way past the switch to the problem. If you can read a schematic you can probably repair this without one.
To georgetwo, Im not sure what you mean? I am using a car battery fully charged to power it up. It has 12V input. I have done this with others. I keep the battery well charged all the time.
To mramos1, There are no schematics available from harbor freight, I did contact them. Yes maybe I can troubleshoot it myself. I am just an amateur when it comes to working on electronics. I have done what you recommended with Google search. there are a lot of them out there, however I did not find much about fixing them.
