need to lower down voltage from power supply
escin
i want to lower down the voltage from 13.8v to 8v. i already try using 33ohm 10watt resisitor,but the voltage is still the same,only the ampere got lower down.
You can make a voltage divider out of two resistors or a potentiometer.
Heres the formula to calculate the resistors values.
Voltage Out = (Voltage In) x R2/(R1+R2)
Since I don't know what value of resistors you have you can mess around with them and see which values you can use.
The 13.8v is the input voltage I don't know why I put it in the schematic but anyone else that would just be the voltage in value.
And ofcourse if you use a potentiometer you can make it variable.
be carful uysing the voltage dividor method, because (as I discovered), as soon as you put a load accross the bottom resistor, it puts a resistance in parallel with the resistor, and changes the voltage completly.
Use a regulator, it will not have these problems, and will add a few extra nice features aswell :)
Tim
