Need to sense and alarm 4vdc
Fairgrove
I have a RV and just installed a monitor to show the level in the waste and fresh water tanks. The monitor has a 0-5vdc output with 0 volts empty and 5 volts full. I would like a way to sense the voltage and activate a buzzer or alarm at 4 volts.
Thanks, Dan
Thanks, Dan
hi Dan,
A simple way would be use a LM393 compartor ic.
The threshold switching level can be set by using a variable resistor.
How are you with electronic circuitry.? how much help do you need.
I am rookie that knows just enough to get in trouble
I need help with a schematic. I have done some very fundamental stuff but I don't think this is all that complicated.
hi Dan,
I'll post a diagram this weekend... unless some other member has one already drawn.:)
hi Dan,
Attached drawing for the LM393 version of the voltage level detector.
I have used the 2nd half of the LM393 as a detector for less than +1V.
Have a look and let me know if its what you looking for.
NOTE: the bleeper is a tone bleep driven from a Vdc fro 5V thru 12V, they are not very expensive.
The relay output option could be used to switch OFF a device when the tank is nearly full. A relay could be added to the 2nd part to control the tank filler.
In order to check out the circuit, I have built it on a project board, it works OK.
Hi Fairgrove,
Here's another one.
on1aag.
