Needed generator's specs
Shohadawy
I have some 6v / 4 AH rechargeable batteries. I'm asking about the proper specifications that should exist in an electrical generator to recharge them.
See if you can find a datasheet from the battery manufacturer, they should have some charging spec. especially for the maximum initial current.
Typically the recharge current is 0.1x discharge spec. (4ah/10 =400ma), you could recharge at a higher rate but this would assume some loss in battery life may occur.
Do you want to recharge these with a small rotating generator/alternator.
To recharge properly you need to:...
  • Not exceed maximum recharge current spec.
  • Monitor battery voltage & terminate recharge when battery voltage reaches that specified by the manufacturer (typically 7.1V for 6V) This is for cyclic use ie: charge, use, recharge....
  • For float use, the battery voltage should be typically 6.75V
