Darkstar64
Hey well im code is almost complete but I am missing one more thing and thats the delay times im a little confused on them so here is what im trying to achieve I multiplexed 12 leds with 4 outputs and 2 inputs to control what operation is exec anyways since only one LED can be on at a time I need them to cycle fast so that it looks like there all on at the same time but really there not they need to be cycling for 3-4 seconds so lets use a letter as a example say J the letter J needs to be on for 3-4 seconds but as stated before only one LED can be on at one time so im unsure how to do this. This is what I have so far I also included the Delay subroutine of 10ms and one of the LED subroutines as well and last but not least the code I have so far this only loops 13 times im not sure how long that is but it needs to loop for 3-4 seconds so the J stays on for 3-4 seconds I also want to add in curcuit programming what do I need electronic wise to seperate the pins from the main electronics so that the PIC can be programmed I was told you couldn't just add the wires you had too seperate the PIC from the main electonics first before you did any programming otherwise it would fry the PIC
;****************** Delay Subroutine ( 10 ms )
delay10 ; Delay W x 10ms
movwf dc3 ; Delay = 1 + W x (3 + 10009 + 3) - 1 + 4 -> W x 10.015ms
dly2 movlw .13 ; Repeat inner loop 13 times
movwf dc2 ; -> 13 x (767 + 3) - 1 = 10009 cycles
clrf dc1 ; Inner loop = 256 x 3 - 1 = 767 cycles
dly1 decfsz dc1,f
goto dly1
decfsz dc2,f ; End middle loop
goto dly1
decfsz dc3,f ; End outer loop
goto dly2
retlw 0
;****************** LED Subroutine
lightledA
movlw b'111010' ; Configure GP4 and GP1 as input
tris GPIO
movlw b'000001' ; Change corresponding bit of GP0 to 1
movwf GPIO ; Writes 1 to GP0
movlw delaytime ; Get from dealytime variable
call delay10 ; Delay of 50 x 10ms = 500ms or .5s
movlw shadow ; Change corresponding bit of GP0 to 0
movwf GPIO
movlw b'101000' ; Configure GP0,GP1,GP2,GP4 to outputs
tris GPIO ; Write 0 to GP0
retlw 0
movlw .13 ; Loops 13 times
movwf cv1 ; Writes 13 to cv1
cv5 call lightledC ; Letter J
call lightledB
call lightledA
call lightledD
call lightledG
call lightledG
call lightledH
call lightledI
call lightledJ
call lightledK
call lightledL
decfsz cv1,f ; Decrement counter is set to 13
goto cv5 ; If Decrement counter is not 0 then repeats loop
