kevin Graber
I will admit from the git-go that i am almost totally electronically illiterate. So please factor that into any responce.
Here is what i am trying to accomplish. I would like to use a toy steam engine dynamo to power a USB port for the purpose of charging phones etc.
Here is a link to a comparable dynamo i would use
i would like a simple device that can purchased as a unit from some electronics supplier like www.linear.com as opposed to building such a thing from scratch. However i realize there may not be any such a component or that slight modification would be needed to existing component, but i am striving for the most simplistic approach.
Standard USB ports output 5 volts and most phones need a minimum of 500 mA so i am looking for some type of regulator that will take fluctuating voltage and cut it off completly if it drop below 5 volts and cap it off if it rises above 5 volts. also it would need some sort of resistor valve (for lack of better term) that would keep the battery from draining back into the dynamo.
I will be happy to provide some financial compensation for a solution as this will be used in commercial application and i will possibly be looking for to pay for some advice in the future as the project develops.
