electronerd213
Hello, and thank you for taking a look at this. I have not been able to come up with a good solution yet, and I may be overlooking it.
I have a system in which I need to read the voltage difference between Neutral and Earth Ground (Vng) on an analog to digital converter (ADC). The ADC is powered by an isolated 3.3V power supply that is powered by mains. What this means, of course, is that the ADC's common is at a level different than the Earth ground (and that level is unpredictable), so I cannot just use a voltage divider directly from Vng into the ADC. Of course, I could just short the DC- to Earth ground, but I am not sure I want to do that.
I have been looking into differential amplifiers and ADC drivers, but I just am not coming up with a good option. Part of the reason for that is that I don't have a DC supply on the board that has the Earth ground as a reference. It's hard for a device to measure a voltage with reference to earth (Vng) when that device does not reference earth.
What I would love is to find a truly differential chip that does not require a supply on the input side, can read up to a 5-10V difference for Vng regardless of the difference between earth ground and the isolated digital ground on the output side, and can reference my isolated digital ground on the output that goes into the ADC. I am also open to I2C or SPI or a lot of other options if those are more available instead of the ADC.
Anybody have any ideas? Things you have worked with?
Thank you!
Thank you!
