Key Performance Specifications:
Oscilloscope
4 analog channels
1 GHz, 500 MHz, 350 MHz, and 200 MHz bandwidth models Bandwidth is upgradable (up to 1 GHz)
Up to 5 GS/s sample rate
20 M record length on all channels
> 340, 000 wfm/s maximum waveform capture rate
Standard passive voltage probes with 3.9 pF capacitive loading and 1 GHz or 500 MHz analog bandwidth
Spectrum Analyzer (Optional)
Frequency range of 9 kHz–3 GHz or 9 kHz–6 GHz Ultra-wide capture bandwidth ≥1 GHz
Time-synchronized capture of spectrum analyzer with analog and digital acquisitions
Frequency vs. time, amplitude vs. time, and phase vs. time waveforms
Arbitrary/Function Generator (Optional)
13 predefined waveform types
50 MHz waveform generation
128 k arbitrary generator record length 250 MS/s arbitrary generator sample rate
. Logic Analyzer (Optional) 16 digital channels
60.6 ps timing resolution
Protocol Analyzer (Optional)
Serial bus support for I2C, SPI, RS-232/422/485/UART, USB 2.0, Ethernet, CAN, LIN, FlexRay,MIL-STD-1553, and Audio standards
Digital Voltmeter/Frequency Counter
4-digit AC RMS, DC, and AC+DC RMS voltage measurements
5-digit frequency measurements
High-Level Description e Performance 6-in-1 integrated oscilloscope with synchronized insights into analog, digital and spectral signals
Commonly Used For Design and Debug EMI Troubleshooting General Purpose RF Design and Integration
Analog Bandwidth 200 MHz, 350 MHz, 500 MHz, 1 GHz
Maximum Analog Sample Rate 5 GS/s
Analog Channels 4
Record Length 20 M
Digital Channels (Optional) 16
Spectrum Analyzer Channel (Optional) 9 kHz -3 GHz (Optional) 9 kHz -6 GHz
AFG (Optional) Up to 50 MHz with 13 functions and arbitrary waveform generation
Serial Bus Analysis Trigger & Decode: I2C, SPI, RS-232/422/485/ UART, CAN, LIN, FlexRay, USB2.0, Ethernet, MIL-STD1553, Audio
Advanced Analysis Power, Limit/Mask, Video, Spectrogram, Vector Signal Analysis
Standard Probing 500 MHz, 3.9 pF or 1 GHz, 3.9 pF
Typical Applications
Embedded Design
Discover and solve issues quickly by performing system level debug on mixed signal embedded systems including today’s most common serial bus and wireless technologies.
Power Design
Make reliable and repeatable voltage, current, and power measurements using automated power quality, switching loss, harmonics, ripple, modulation, and safe operating area measurements with the widest selection of power probes in an affordable solution.
EMI Troubleshooting
Quickly track down the source of EMI in an embedded system by determining which time domain signals may be causing unwanted EMI. See in real-time the effects time domain signals have on system EMI emissions.
Wireless Troubleshooting
Whether using Bluetooth, 802.11 Wi-Fi, ZigBee, or some other wireless technology, the MDO4000C enables viewing an entire system – analog, digital, and RF, time-synchronized to understand its true behavior. Capture an ultra-wide band in a single capture to view interactions among multiple wireless technologies, or to view an entire broadband frequency range from a modern standard like 802.11/ad.
Education
Managing multiple instruments on a bench can be troublesome. The MDO4000C eliminates the need to manage multiple instruments by integrating six instrument types into a single instrument. The integration of a spectrum analyzer enables teaching of advanced wireless technology course work while minimizing the investment required. Full upgradability enables adding functionality over time as needs change or budgets allow.
Manufacturing Test and Troubleshooting
Size and space constraints can play havoc on a manufacturing floor. The unique 6-in-1 MDO4000C minimizes rack or bench space by integrating multiple instruments into one small package. Integration reduces cost associated with utilizing multiple different instrument types in manufacturing test or troubleshooting stations.
Specifications
Analog channels 4
Analog channel bandwidth 1 GHz
Rise time 350 ps
Sample rate (1 ch) 5 GS/s
Sample rate (2 ch) 5 GS/s
Sample rate (4 ch)
Without option SA3 or SA6
With option SA3 or SA6
5 GS/s
2.5 GS/s
Record length (1 ch) 20 M
Record length (2 ch) 20 M
Record length (4 ch) 20 M
Digital channels with MDO4MSO option 16
Arbitrary Function Generator outputs with MDO4AFG option 1
Spectrum analyzer channels with option SA3 or SA6 1
Spectrum analyzer frequency range
With Option SA3
With Option SA6 9 kHz – 3 GHz
9 kHz – 6 GHz
Oscilloscope
4 analog channels
Analog Channels 4
Record Length 20 M
Embedded Design
Power Design
EMI Troubleshooting
Education
Specifications
Analog channels 4
Rise time 350 ps
Sample rate (4 ch)
5 GS/s
2.5 GS/s
With Option SA3
9 kHz – 6 GHz
