new to Multiplexer
GilbertSam
Hi All,
Need your help here.
Let say the Y(A,B,C) = {1,3,4,6}
By using a 4:1 multiplexer, how are we going to construct the circuit which can implement the logic function above?
Please advice,
Gilbert
MULTIPLEXER - Asignment Question
Hi All,
Please help on this. I just able to build it for 8:1 Multiplexer as shown in attached for Out ( A, B, C ) = {1,3,4,6}. How am I going to convert it to only ONE 4:1 Multiplexer?
Please advice and guide,
Thanks in advance,
Gilbert
  • Doc1.doc
You can do this with a 4:1 MUX, but you need an extra invert gate in there too.
Your system is:
000 0
001 1
010 0
011 1
100 1
101 0
110 1
111 0
Your code has reflected symmetry about the 011/100 transition. Therefore:
Use a 4:1 MUX as follows:
00 0
01 1
10 0
11 1
Then from the remaining bit, drive an inverter to invert the output of the MUX. this will give you:
(0)00 0
(0)01 1
(0)10 0
(0)11 1
and when your other bit (the most significant bit) is 1, it inverts the output to give
(1)00 1
(1)01 0
(1)10 1
(1)11 0
Hope this helps:D
Then
Hi Bill Naylor,
If the select lines for the 4:1 multiplexer is AC, what should be the connection for the input of multiplexer ?
Please advice,
Thanks & Best Regards,
Gilbert
