As of today, when I edit a post and click save, I am stuck at my edited post, as in it does not appear as though I saved. I have to manually exit, and the post is saved.
If you select 'go advanced' and Save, does that work as normal, this is what I have to do.
That may be a work around. Point is, that I have clicked save and exited for a long time now. Suddenly it no longer works. I am able to adapt and make keystroke changes if need be, just thought I would point out something has changed. Since the forum has new code, I suspect EM wants input.
Thanks for the tip though
Same observation from me . But i fear this has been happening in many other sites even.As of today, when I edit a post and click save, I am stuck at my edited post, as in it does not appear as though I saved. I have to manually exit, and the post is saved.
Webpage error details
User Agent: Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.0; WOW64; Trident/4.0; GTB5; Mozilla/4.0 (compatible; MSIE 6.0; Windows NT 5.1; SV1) ; SLCC1; .NET CLR 2.0.50727; .NET CLR 3.0.04506; Media Center PC 5.0; InfoPath.2; .NET CLR 3.5.21022)
Timestamp: Wed, 8 Apr 2009 10:52:09 UTC
Message: Object required
Line: 11
Char: 7887
Code: 0
URI:
Line: 11
Char: 7887
Code: 0
URI:
Okay just upgrade some of the seo url rewrites which has been known to do this. Test away ppl. I believe its now fixed!
But E M , how to understand the delay while loading. this was not so earlier. it used get loaded much faster.Okay just upgrade some of the seo url rewrites which has been known to do this. Test away ppl. I believe its now fixed!
YesCan you please be more specific? What is loading slow for you?
