i am doing a program for temperature control (temp max is 40deg)....if it exceeds start a fan at 80% duty cycle......
i am getting this error when i build it;;;
Error[128] C:\USERS\PRAVEEN\MPLAB\GDADC.ASM 51 : Missing argument(s)
when i click it is pointing to GOTO PWM80 line in the program......
i am using mplab ide v 8.20.....don know wat code tags are...
LIST P=16F877 ; XTAL 20 MHZ
Stimulus: Synchronous stimulus applied successfully.
CORE-W0014: Halted due to PC incrementing over the Maximum PC address and wrapping back to Zero
#include<p16f877a.inc>
#DEFINE LOOP ; if i did not use this it was givin an error symbol nt previously defined
#DEFINE PWM80
#DEFINE PWM20
#DEFINE PWM1
ORG 0X00
REG1 EQU 0X29
RES1 EQU 0X30
RES2 EQU 0X31
MOVLW 0XFF
BANKSEL TRISA
MOVWF TRISA ;PORTA I/P
BANKSEL PIE1
BCF PIE1,ADIF ;DISABLE ADC INTERRUPT
BANKSEL ADCON0
MOVLW 0XC1
MOVWF ADCON0 ; RA0 AS ADC PORT
MOVLW 0X80
BANKSEL ADCON1
MOVWF ADCON1 ; PORTA FOR ADC CHANNEL..RIGHT JUSTIFICATION
;SUBROUTINE GETADC===============================
LOOP BANKSEL ADCON0
BSF ADCON0,GO ; start a/d conversion
ADCLOOP BTFSC ADCON0,GO ;WAIT FOR CONVERSION TO FINISH
GOTO ADCLOOP
BCF PIR1,ADIF ; CLEAR CONVERSION COMPLETE FLAG
;COMPARISON WITH THE SETPOINT====================
MOVF ADRESL,W
SUBLW .83 ;FOR SETPOINT 40 DEGREES
MOVWF RES1
BTFSC RES1,7 ; CHECK WHETHER THE MSB IS 1 ,IF SO IT MEANS
; THAT TEMP>40 HENCE CALL 80% PWMDUTYCYCLE
GOTO PWM80
SUBLW .73 ; FOR 35 DEGREES
MOVWF RES2
BTFSC RES2,7 ;CHECK WHETHER THE MSB IS 1 ,IF SO IT MEANS
; THAT TEMP>35 HENCE CALL 20% PWMDUTYCYCLE
GOTO PWM20
GOTO PWM1 ; IF THE ABOVE TWO CONDS DOES NT SATISFY CALL
; 1% PWMDUTY CYCLE
;PWMCYCLES==========================================
PWM80 BANKSEL PR2
MOVLW 0X31
MOVWF PR2 ; FREQUENCY IS SET FOR 10MICROSECS
BCF STATUS,RP0
BCF STATUS,RP1
MOVLW 0X48
MOVWF CCPR1L
MOVLW 0X0C
MOVWF CCP1CON
;TRISC Setting for output
BANKSEL TRISC
BCF TRISC, PWM1
BANKSEL T2CON
;TMR2 Prescale selection(PRESCALE TO 1:16 AND POSTSCLE TO 1:1) and TMR2 Turn On
MOVLW 0X07
MOVWF T2CON
GOTO LOOP
PWM20 BANKSEL PR2 ;FOR 20%DUTYCYCLE
MOVLW 0X31
BCF STATUS,RP0
BCF STATUS,RP1
MOVLW 0X0A
MOVWF CCPR1L
MOVLW 0X0C
MOVWF CCP1CON
BANKSEL TRISC
BCF TRISC, PWM1
BANKSEL T2CON
MOVLW 0x07
MOVWF T2CON
GOTO LOOP
PWM1 BANKSEL PR2 ; FOR 1% DUTYCYCLE
MOVLW 0X31
BCF STATUS,RP0
BCF STATUS,RP1
MOVLW 0X00
MOVWF CCPR1L
MOVLW 0X2C
MOVWF CCP1CON
BANKSEL TRISC
BCF TRISC, PWM1
BANKSEL T2CON
MOVLW 0x07
MOVWF T2CON
GOTO LOOP
END
pls help me out...........how to solve this....
#DEFINE PWM80
#DEFINE PWM20
#DEFINE PWM1
ORG 0X00
REG1 EQU 0X29
RES1 EQU 0X30
RES2 EQU 0X31
MOVLW 0XFF
BANKSEL TRISA
BANKSEL PIE1
BANKSEL ADCON0
MOVLW 0XC1
MOVLW 0X80
BANKSEL ADCON1
LOOP BANKSEL ADCON0
GOTO ADCLOOP
MOVF ADRESL,W
MOVWF RES1
GOTO PWM80
MOVWF RES2
GOTO PWM20
; 1% PWMDUTY CYCLE
PWM80 BANKSEL PR2
MOVLW 0X31
BCF STATUS,RP0
BCF STATUS,RP1
MOVLW 0X48
MOVWF CCPR1L
MOVLW 0X0C
MOVWF CCP1CON
BANKSEL TRISC
BCF TRISC, PWM1
BANKSEL T2CON
MOVLW 0X07
MOVWF T2CON
GOTO LOOP
MOVLW 0X31
BCF STATUS,RP0
BCF STATUS,RP1
MOVLW 0X0A
MOVWF CCPR1L
MOVLW 0X0C
MOVWF CCP1CON
BANKSEL TRISC
BCF TRISC, PWM1
BANKSEL T2CON
MOVLW 0x07
MOVWF T2CON
GOTO LOOP
MOVLW 0X31
BCF STATUS,RP0
BCF STATUS,RP1
MOVLW 0X00
MOVWF CCPR1L
MOVLW 0X2C
MOVWF CCP1CON
BANKSEL TRISC
BCF TRISC, PWM1
BANKSEL T2CON
MOVLW 0x07
MOVWF T2CON
GOTO LOOP
END
