Newbie Power Supply Question
MrJammin
I'm new to PIC programming and recently bought a PIC programmer off EBay. It came with a PIC programmer that connects via a USB cable. Attachable to that programmer is the ZIF socket that holds the actual microcontroller. Since I am utilizing the USB port to power the programmer the software tells me that I need to find a seperate power supply for the target chip in the ZIF socket. I am just having trouble figuring out how to power the IC in the ZIF socket. Do I just lead in the appropriate power and ground wires to the pins of the IC or do I utilize this array of pins on the corner of the board(picture attached).
Going by the programmer I buit, VPP is normally 13V and VDD is nomally 5V.
You can buy mains adaptors with a 5V output but the 13V is a bit more difficult.
12V might work though, a 12V regulated adaptor could supply you with the 5V if you add a LM78L05 regulator on the output.
If 12V doesn't work then you really need 13V, then you could use the power supply from the PIC programmer on Nigel's site:
https://www.electro-tech-online.com/custompdfs/2007/06/p16pro40-1.pdf
thats strange, programmer asking for external power source is understandable but its asking also for PGD & PGC !!! whats the usb for then ?
looks like the ports you showing is for ICSP.
I'm trying to program the PIC16F628A. Here is the ebay auction of the PIC programmer I bought: **broken link removed**
So if I were to power the target separately, since I am powering the programmer with the USB port, would I just run power and ground wires into the ZIF socket?
No you don't power the programmer with USB. USB gives only 5 V but you need Vpp which is 13 V.
Ya, it should have maybe an adapter to the programmer board, then there should be a socket connected from the board to the zif.
