ngspice transfer function
ced
I am a ngspice newbie and I'd like to get a frequential transfer function of a Wien filter
as an exercise .
I'd like to plot V(3)/ISRC versus frequency .
Here is the .sch file I simulate :
Tranfer function
ISRC 1 0 AC 1
R1 1 2 1k
C1 2 3 1u
R2 3 0 1k
C2 3 0 1u
.AC DEC 10 1 10K
.END
Here is the result I get :
ngspice 1 -> run
Doing analysis at TEMP = 27.000000 and TNOM = 27.000000
Warning: Source isrc has no value, DC 0 assumed
Warning: singular matrix: check nodes 1 and 1
Note: starting dynamic Gmin stepping
Trying gmin = 1.0000E-03 Note: One successful Gmin step
Trying gmin = 1.0000E-04 Note: One successful Gmin step
Trying gmin = 1.0000E-05 Note: One successful Gmin step
Trying gmin = 1.0000E-06 Note: One successful Gmin step
Trying gmin = 1.0000E-07 Note: One successful Gmin step
Trying gmin = 1.0000E-08 Note: One successful Gmin step
Trying gmin = 1.0000E-09 Note: One successful Gmin step
Trying gmin = 1.0000E-10 Note: One successful Gmin step
Trying gmin = 1.0000E-11 Note: One successful Gmin step
Trying gmin = 1.0000E-12 Note: One successful Gmin step
Warning: Dynamic Gmin stepping failed
Note: starting source stepping
Supplies reduced to 0.0000% Warning: singular matrix: check nodes 1 and 1
Trying gmin = 1.0000E-02 Note: One successful Gmin step
Note: One successful source step
Supplies reduced to 0.1000% Warning: singular matrix: check nodes 1 and 1
Warning: source stepping failed
AC operating point failed -
Last Node Voltages
Node Last Voltage Previous Iter
1 0 0
2 0 0
3 0 0
doAnalyses: iteration limit reached
run simulation(s) aborted
Does someone has an idea about what's wrong in the scheme file ?
Thanks for your help,
ced
I know nothing about NGSpice (No Good Spice?).
Driving the Wien Bridge network with a current source is a problem. The input should be from a voltage source. Look at the two frequency sweeps in the attachment. The second is the correct behavior.
Get the free LTSpice.
ngspice is a linux spice simulator, it was a bad joke :) !
Actually it works fine as long as their is a dc path between any node and ground.
I've added a large resistor between node 1 and ground, and it works fine .
I'll try soon LTspice
Thanks and bye,
Cédric
Thanks and bye,
Cédric
I think that Mike was implying that the Vout/Iin transfer function is almost trivial, because the values of R3 and C3 (in his schematic) are irrelevant. If you don't believe me, try changing R3 and C3.:eek:
I agree that the Vout/Iin transfer function is trivial .
I am spice beginner, so to gain confidence, I'd like to see well-known results, before
trying to simulate circuits that I don't precisely know .
I thought it would an easy way to get the impedance versus frequency of a network
plotting the voltage between the nodes of the network versus frequency with a 1A AC
input current .
Does that seem right to you ?
Vout/Iin is definitely a good way to plot impedance. With 1 Amp in, the result is in Ohms, which is of course what you were implying. It's not a great way to plot Vout/Vin, which is what you need for a Wien network. You can do it with current stimulus, but you have to do some math in the plot (Vout/Vin) to get useful information.
