Just wondering if this is a version bug or my corrupted program. I've tried everything to no avail. If you have used version 8.56 and were able to get line numbers and mouseover then maybe I'll try a reinstall.
The line numbers do appear as far as 9 but no further.
Could be a corrupt Mplab or something on your PC system.
I would first take a backup of your MPlab work files just incase, then uninstall v8.56 which normally leaves your work files intact, then download and install 8.83 the latest version and see if that cures the problem, no reason why you should stay on 8.56.
I installed v8.83 and noticed that the mouseover only works on capitalized registers. Thats most likely my problem as I am not a good typist so disable case sensitivety and use lower case.
BUT the line numbers still don;t go past 9. Thanks Aaron
No matter what I do I only get line numbers 1-9. Tried clearing all selections in asm file types, closing program, then reopening and enabling line numbers but still only get 1-9.
They are not features I use and seem not to be enabled by defualt.
Have just enabled them in the Edit, Properties, ASM and ToolTips menus and they work ok; line number down the LH side and the variables address and value when you hover over them.
