johnsmith123
Hey Guys, I have a set of motorola FRS radios that contain a 6V rechargeable battery. As with most batteries, after 6 months the battery is no longer functioning.
The radio is stationary, therefore I do not need the wireless benefits of having a battery,and it can be plugged in for the power supply.
I built a 6 volt power supply to bypass the battery using an LM317 circuit which I found.
There is no connection for external power on the radio, so I removed the battery and hooked up the wires from the 6Volt power supply I built, directly to the battery terminals.
I installed a 1000uF cap to filter the power on the input and a 10uF cap on the output (6Volt) connection.
I have tried other wall adapters(some noisier than others), however I am getting a great deal of noise when using the radio, so much that it is unuseable.
I am just wondering if someone knows of a power supply that can be built easily and cheaply to do this task noise free? Or maybe a mod that I can do for my existing circuit.
I also tried an L78M06 regulator, still lots of noise.
I was using a power supply for my XM radio that is exactly 6Volts DC with no noise at all, it works well. This is a 12Volt lighter plug I use in my car to power the XM radio. I don't want to purchase one of these power supplies if I don't have to.
Any help/suggestions on how I can eliminate the noise will be appreciated.
