StudentSA
Hi All!
I have a Raspberry Pi 3 that I am trying to use together with an FM module called the TEA5767 i.e. the 5V, SDA, SCL and GND are all from the Pi's GPIO.
The issue I am having is that there is a background ticking noise from the output. Sounds almost like a helicopter is the distance.
So, I have been trying to isolate the issue and these are my findings:
1. If I shutdown the pi, the noise goes away. i.e. the pi still supply 5V but the processor etc is off.
2. If the Pi is on and I disconnected the SDA and SCL lines, no effect, noise still persists with the module located near or far.
3. If I connect only Vcc and GND of the TEA to another isolated 5V supply. Noise is gone when more that 10cm away from the pi. As I move the board over the pi the ticking sound returns. the closer I get the louder it ticks
4. I tried wrapping the tea module in foil as much as I could but still noise.
Any advise is appreciated.
![FM_sterio_module_jpg-101713-500x500.jpg](https://www.pishop.co.za/store/image/thumbnails/18/d5/FM_sterio_module_jpg-101713-500x500.jpg)
