white knight
I have neighbours from hell with music heard in the street 50 meters down the road, the authorities do nothing so I thought natural law and technology would help.
Other forums give solutions, but miss full instruction, so I thought I would find technical forums and ask qualified people for there opinion.
QUOTE-
You need a CB radio, A linear amp, and a bottom loaded CB antenna with no ground pane. See if you can get a good guess where she has her [speakers] set up and get your antenna close as you can to it. You should be able to talk to her THROUGH their stereo system. The amplifier sections are not shielded in these plastic ready made toys and the resulting AM signal will impact it. In my case I ran a continuous 6khz tone from a signal generator which was more than enough to blow it up good
- I don't understand how a 6khz tone from a signal generator which was more than enough to blow it up good. Does that mean damage it? Is that possible? I would of thought only substituting your broadcast sound over theres would be the only option.
Does it work if there speakers are off?
Another article says the CB radio has a 100 watt minimum linear amplifier; preferably an amp with a 100% duty cycle.
What part is the 100 watt minimum. This amp below says its 180w, but it says in the specs its output power is 45w max
https://www.ebay.co.uk/itm/180W-Lin...524073?hash=item2cb4c757e9:g:sHwAAOSwMVdYEvUQ
What am I looking for when it says 100 watt minimum.
another person says AM CB radio is the default FM, another talks about the effectiveness of the SSB (Single Side Band) CB radio, and they weren't using a linear amp, just a Cobra SSB 23 channel and a magnetic mount whip antenna.
Can anyone confirm what to use?
Another source says you don't even need the antenna use 50 ohm dummy load.
Is that a good idea, how does that setup work?
Also incase anyone brings it up, linear amplifiers are legal in the UK.
eBays buying guide says if they are not correctly tuned they can interfere with other devices, TVs, stereos etc
see section
How to Hook Up a CB Radio Amplifier
and Conclusion
https://www.ebay.co.uk/gds/CB-Radio-Amplifiers-Buyers-Guide-/10000000177317681/g.html
Not sure what it means there, thats what I want to do.
QUOTE-
see section
and Conclusion
