Nokia 6100 Library
AtomSoft
Hey guys great news!!! Im making a Nokia 6100 Color LCD library. WIll use SPI BitBang , 12bit color per pixel. Here is a image of some progress:
6100-jpg.34800
So far i have:
CIRCLE, RECTANGLE, CHAR, STRING, BASIC COLORS
Very nice. I ended up destroying the connector on my 6100. Watch if you try to unplug it from the board. It's definitely a pretty little LCD and not too hard to develop for. Main problem I've seen is the complaints about the different versions.
If anyone finds a really cheap source, I might get another one or two, but right now I haven't found a need to replace my old broken one.
Sorry lol forgot... I got it from eBay.. Came on a noce board for $15 .. You can also get from sparkfun cheaper but no board ..
I'm tired like crazy..I'll post links in a little bit
Ok im working in VB6 and so far i can open a image and get the RGB of each pixel. Im not sure if im converting it correctly since i havnt tried it yet. But since the RGB is 4-4-4 for this LCD to be 12bit .... Im diving the 255,255,255 by 17 each this way the max of 255 is turned into 15(F)(1111) which is 4 bits.
I hope this works heh.. Now i have to code the creation on data bytes. I need to connect every 2 parts together to make one byte and if then append a 0 to the end if need be (odd amount of pixel data)
Wish me luck. Remember all the code and stuff will be shared and posted when complete or if i quite (most likely complete :D )
I am about to test out some hex it generated ill post a comment on it in a bit
24x9 bmp of 4 main colors RGB and Black
240,15,0,240,15,0,240,15,0,240,15,0,240,15,0,240,15,0,240,15,
0,240,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,
0,0,0,0,0,0,240,15,0,240,15,0,240,15,0,240,15,0,240,15,
0,240,15,0,240,15,0,255,0,240,15,0,240,15,0,240,15,0,240,15,
0,240,15,0,240,15,0,240,15,0,0,0,0,0,0,0,0,0,0,0,
0,0,0,0,0,0,0,0,0,0,0,0,0,15,0,240,15,0,240,15,
0,240,15,0,240,15,0,240,15,0,240,15,0,240,15,240,15,0,240,15,
0,240,15,0,240,15,0,240,15,0,240,15,0,240,15,0,240,0,0,0,
0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,
0,240,15,0,240,15,0,240,15,0,240,15,0,240,15,0,240,15,0,240,
15,0,255,0,240,15,0,240,15,0,240,15,0,240,15,0,240,15,0,240,
15,0,240,15,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,
0,0,0,0,0,0,0,0,15,0,240,15,0,240,15,0,240,15,0,240,
15,0,240,15,0,240,15,0,240,15,240,15,0,240,15,0,240,15,0,240,
15,0,240,15,0,240,15,0,240,15,0,240,0,0,0,0,0,0,0,0,
0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,240,15,0,240,
15,0,240,15,0,240,15,0,240,15,0,240,15,0,240,15,0,255,0,240,
15,0,240,15,0,240,15,0,240,15,0,240,15,0,240,15,0,240,15,0,
0,0,0,15,0,240,15,0,240,15,0,240,15,0,240,15,0,240,15,0,
240,15,0,240,15,240,15,0,240,15,0,240,15,0,240,15,0,240,15,0,
240,15,0,240,15,0,240,0,0,0,0,0,0,0,0,0,0,0,0,0,
0,0,0,0,0,0,0,0,0,0,0,240,15,0,240,15,0,240,15,0,
240,15,0,240,15,0,240,15,0,240,15,0,255,0,240,15,0,240,15,0,
240,15,0,240,15,0,240,15,0,240,15,0,240,15,0,0,0,0,0,0,
0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,15,0,
0,240,15,0,240,15,0,240,0,0,0,0,0,0,0,0,0,0,0,0,
RGB and black? What the heck colour pallet are you using?
RGB at all FFs is white, RGB at all 00s is black, if you have a fourth colour it's either an alpha channel a mask or you badly mistyped something.
heh i mean im trying RED, GREEN, BLUE, WHITE and BLACK color image...
I ran into a issue::
MAX = unsigned long
the width and height = unsigned char
    max = width * height;
My problem is if width = 50 and height = 50 max should = 2500 but it = 196
any thoughts????
dude for this display it uses 4 bit color for each RGB so
RED = 4 bit
GREEN = 4 bit
BLUE = 4 bit
Now if pixel 1 is solid red you get F0,0
and if pixel 2 is solid blue you get 0F,0
but as decimals so thats.... 240,0,240 the way the lcd works is it will read the 2 bytes like
RRRRGGGG,BBBBRRRR,GGGGBBBB = 11110000,0000,11110000
you see?
That makes even less sense atom....
RGB....
All 00s == black. All FFs == white. There should be no separate bytes other than R G and B.
hey guys this is killing me:
void LCDWriteBMP(unsigned rom char *bmp, unsigned char x, unsigned char y, unsigned char width, unsigned char height) {
unsigned int j;
unsigned int maxPix;
unsigned int xmin, xmax, ymin, ymax;
unsigned int i;
    maxPix = 0;
    //maxPix = (width * height);
    for(j = 0; j < height; j++) {
        maxPix += width;
    xmin = x;
    xmax = x + width;
    ymin = y;
    ymax = y + height;
    LCDCommand(PASETP);
    LCDData(ymin);
    LCDData(ymax);
    LCDCommand(CASETP);
    LCDData(xmin);
    LCDData(xmax);
    LCDCommand(RAMWRP);
    for(j = 0; j < maxPix; j++) {
        LCDData(*bmp++);
The above might work well... I call it like:
LCDWriteBMP(bmp444,20,20,50,50);
for some reason the values are mixed up or wrong..
err-jpg.34894
MAX = unsigned long
any thoughts????
The calculation is being done in unsigned char (i.e. multiples of 256 are being dropped in the result), put another way:
2500 = hex 9C4
Hex C4 = 196
You need to force the calculation to be done in unsigned long
max = width;
max = max * height;
would probably do it or you could probably use explicit type casts.
the issue was it wasnt getting the data from the call but i fixed it somewhat;
    width = *bmp++;
    height = *bmp++;
        maxPix += width;
but ill try your suggestion for the math tho
UPDATE:
    width = *bmp++;
    height = *bmp++;
    maxPix = height;
    maxPix = maxPix * width;
Works well! thanks
