Hello.
I want to power a laser pointer from a uC, a simple ON/OFF mechanism. But the output-PIN can only output or sink 20mA, while the laser requires 100mA. They both run on 5VDC.
My questions:
1: What do I do? I guess I can use a transistor (or maybe an op-amp?).
2: How will I design the circuit? Do I need any resistors or caps in between the components?
3: If you could suggest a transistor (or op-amp) that would suit my needs that would be perfect (SMD components are preferable). Or maybe just point out what values I should look for in the datasheet.
I really appreciate any help
Thank you!
My questions:
