Resource icon
Notch Filter Allows Single Pot Adjustment of Notch Frequency With Little Change In Its High Q Value 2018-06-01
crutschow
Most Helpful Member
crutschow submitted a new article:
Notch Filter Allows Single Pot Adjustment of Notch Frequency With Little Change In Its High Q Value - Notch filter Q is largely independent of component tolerances and notch frequency adjustment.
In some low frequency signal applications a single frequency interfering noise signal, such as from a 50/60Hz main's frequency, can be a problem and it is desired to suppress it with a notch filter with high attenuation at that frequency.
When using a high-Q notch filter to reject such a specific frequency, it generally is required to tweak the notch frequency due to component tolerances, so that the notch is exactly at the desired frequency.
Unfortunately, most typical notch circuits...
Read more about this article...
