Hello everyone,
I'm trying to build an OBD interface to be able to read data from cars. The idea is to use an arduino and some cheap hardware to handle "low-level" protocols, and to get the arduino connected to a laptop, which will take care about the OBD2 protocol.
Based on some opensource projects, I designed this scheme (See the attached).
I'm planning to use https://github.com/iwanders/OBD9141 for ISO 9141-2 and ISO 14230-2, https://github.com/matafonoff/J1850-VPW-Arduino-Transceiver-Library for J1850-VPW and https://github.com/coryjfowler/MCP_CAN_lib for CAN, and so, I should be able to work with four protocols on five.
My questions are the following: Is that gonna work or not ? Do I have an error in my scheme ? Adding a circuit to power all the transceivers in 12v will it be enough ?
Thank you for reading
