There`s lots of you looking for this ellusive cap.,There seems to be plenty in the USA. but none in the UK.the 8.2nF equates to 0.0082uF MFD. or 8200pF MMFD.The nearest value in the conversion chart is 0.01uF. This cap seems to work o.k. as a substitute.
Hi, Monkey,thanks for the reply,I never thought of that.surprising how you miss the simple things.I was wondering what the result would be if I just left it out?
Thanks for that,I`ll keep to the values.You may also be able to help me with this;what does 8n2 equate to in uF? also there are caps between the pins of the Bass pot,marked 472 & 473,what do these convert to in uF.The reason I`m asking is my supplier`s chart (Maplins) only shows values in uF.Thanks again,Terry
