First off heres how it came to be. My dad has been having well problems all summer. The well is a 1950's era type still with the old mechanical pump jack design that sits in a dog house like box in his front yard. Its been there all my life.
Anyway he has spent all summer trying to get a well driller out to check it over and see why it pumps so slow. Under 1 quart a minute on average.
Finally one well driller called back and said he would change it over to the modern submersible type for around $2000. No one else Will touch it because its too old and has been obsolete for about 30 years.
Yesterday I pulled the top off and lifted the pit less unit and first 14 feet of pipe out with the tractor and found it was not hard to convert it to a modern submersible type. Basically change a fitting and drop the new pump in. I purchased the whole pump, 200 feet of water line, wire, fittings and new well cap for $540.40
I started the change out this morning. I got the first section of the old pump line out and it went easily too.![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
The problem came with the second section of pipe. The first one I had one lifting chain and two back up holders to keep it from falling down the well. The second section for some odd reason I took both backup holders off the pipe while I was lifting it.![Eek! :eek: :eek:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Too early in the day and not thinking clearly is as best as I can recall. Basically I dropped the whole 160 -180 feet of pumping pipe and rod down the well when the lifting chain slipped because I didn't wrap it right.![Eek! :eek: :eek:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I was told and everyone in the family has said that the well is about 200 feet deep and the lower pump cylinder is at about 160 -180 feet from the surface. I put some big nuts on a string and dropped them down the well to find out how far down they ended up. I thought I hit the top of the pipe at about 40 feet down. So I went home and made a jig that would be able to grab the pump rod sticking out of the pipe.
Assuming it was a 200 foot well and the top of the assumed pipe was at 40 feet down made sense. I came back with my jig and dropped it down the well on 65 feet of cable. Nothing all the way down to 65 feet. Hmmm...
I went home and made a bigger and heavier weight that just fit the well casing and then dropped it in on the end of a 20000 foot roll of bailing twine. Clunk at 130 - 140 feet.
Apparently no one ever got the depth of the well surveyed before when the pump system had been overhauled over the decades. Apparently the 200 Foot well is around 300 feet actual depth. And whats interesting is the water comes up to about 20 feet from the top! Had it been placed in the valley floor a few hundred feet away instead of up in the yard it would likely free flow right out the top.
So that dad would have water tonight I set up the new pump on 100 feet of line and I plan to finish pulling out the old pumping system tomorrow. He is not overly upset about it and actually is pleased to know the well is that deep. I have to get more new line and wire and once the old pump parts are out the new pump is going to be set at about 290 feet!
Unfortunately the new pump at 100 feet delivers about one quart a minute once the reserve in the well casing is used up so the well is likely going bad and the old system was probably still working normally anyway.![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
But still I get paid half of the contractors bid price for doing the work! It will just take two days instead of one.![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I may have screwed up from not paying attention to what I was doing and I fully admit I am a horrible worker in the early part of the day. I know better than to get excited about doing work that takes concentration and focus before I have been awake for a few hours. I've done more stupid stuff in the first four hours after I wake up then any other time of the day. I should just know better by now.![Mad :mad: :mad:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
but still I will get the job done just the same. Tomorrow I am making a self locking clamping system that wont let me drop it again before I even try to lift it out!![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
