Contemplating making an intake air density meter for my car. Part plan, part thought experiment.
I have a MAP sensor and can add a thermistor. These will give me voltage readings more or less proportional to temperature and pressure.
Using op-amps (or other linear devices) is it possible to divide pressure by temperature and thus obtain a relative density ?
In theory this would be useful for evaluating intake modifications as most have a tendency to trade between heat and pressure loss - i.e. remove the entire intake, and you get low pressure / drag losses, but increase temp. On the other hand, a long cold air intake may reduce the intake pressure such that you lose out again.
I know this could be done with a PIC, or probably even a PICAXE, but I'm curious if it can be done without it.
