audioguru said:Any opamp works fine from a single supply voltage if its input is biassed near half the supply voltage with two resistors and input and output coupling capacitors are used.
The OPA2134 dual opamp can have a sine-wave output of 5V p-p up to about 1.5MHz if its gain is only 1. The sine-wave might look nasty because at such a high frequency the opamp doesn't have much negative feedback. Above 1.5MHz its output will be slew-rate limited into a triangle wave.
Square-waves above about 50kHz will have sloping rise and fall edges.
