hello guys I'm working on a line follower robot and i built following circuit as line sensor.
circuit
it uses LM324 opamp as a comparator and RED LED as a sensor.
Circuit does what is built to do-identifying difference between black-white surface but it still has little problem.if i touch the circuit while its working it changes its readings.-its like op amp responds to static charge(or something like that) in my body.
So i was thinking if I replace LM324 opamp with LM339 comparator IC will this help to solve the problem?
replace
and is there any quad comparator IC with same pinout as LM324? (LM339 has different pinout so i will have to built circuit all again
thank you
circuit
replace
thank you
