hi everyone,
i have sensor measuring current but i am having problem with conditioning signal. sensor makes output 0.5...4.5VDC (corresponds to input change -5 to +5A). this should be fine to bring directly to ADC (MCP3208) when measuring DC currents.
btw. i would really really like to stick with 5VDC single supply (ok, it can be up to 12V if needed).
the problem I have is if the current is AC. this 0.5...4.5V need to be rectified (using 2.5V as zero reference since this voltage represents zero current). I know that classic rectifier will not work because of forward drop on diodes. i did find "precission rectifier " or "super diode" circuit but quick test on a breadboard showed that is is trickier than it sounds. among other things, normal opamps like LM358 don't swing beyond 1.1..3.9V when powered by 5V.
can anyone offer ideas or possible solution? i'd like some slick circuit with just a jumper or dipsw. to select AC or DC circuit behavior.
i used this as reference but tested with LM358 which i had laying around:
http://www.freecircuits.net/circuit-61.html
other changes are:
- removed C1 (didn't think AC coupling is needed),
- single supply, created virtual ground using pair of 2k2 resistors and cap. to gnd.
- inserted switch in series with R5 (trying to select AC/DC)
so far i didn't have much luck with test circuit on a breadboard, will re-check...
johnny s.
other changes are:
johnny s.
