Styx
Active Member
If you open-cct an inductor while current is flowing an arc will form to maintain the current-flowing (to satify V=Ldi/dt).
However...
IF the inductor is in a perfect vacuum (with no atoms of gas) and the coils were such that they were not touching each other (dont even need any insulation around wire).
If you got a current established and THEN open-cct the inductor what will happen?
since there is no "atmosphere" to ionise an arc cannot form, or can it?
as far as I can figure out one of two things will happen
1) infinite voltage would develope across the terminals
2) the copper at the terminal ends would start to vapourise under the extreamly high electro-field (not infinite) and the liberated copper atoms/electrons would facilitate an arch.
#2 is what I am leaning towards but what kind of voltage would be needed?
However...
