Hello. I intend to buy an optical encoder in order to use it to calculate the speed of a rotating wheel. However, it says in the datasheets of the encoder that the operating current is around 80 mA but that "an inrush current of 9 Amps flows for about 0.3 ms when it is switched on". The power supply I am using at the bench provides a maximum current of 5 Amps. Will this be a problem? Will the encoder fail to operate if the initial current of 9 Amps is not fully received and could this damage my power supply? Thanks a lot.
