Optical Tachometer with LED readout.
WilliamN
I am looking for a schematic of a optical tachometer circuit with a LED read out. Its intended to measure the the RPM of a jet engine compressor shaft. Very high rpm range, around 120,000 RPM max. Any help would be great.
William
That is only 2kHz, even with lots of vanes, you can easily measure this with a microcontroller like an AVR or PIC. The easiest way to proceed is just use an LED and a phototransistor. The transistor drives either an input capture or counter input to the micro, then you can measure the time between pulses to find the frequency of count for a fixed amount of time. Having said that, I dont think I want to be the one holding this gizmo up to a jet engine. You would also have to find some way to make a very sturdy mount.
