StudentSA
Good Day,
I am really struggling to get a "simple" Triac circuit to work. I started by consulting the typical application from the optocoupler MOC3043 datasheet:
I chose the MOC3043M as is was suggested for 240Vac operation and had the lowest "turn-on" current (5ma).
I've constructed the circuit exactly (Fig 13) as is except I have pin 2 to ground and Vcc is Vin of a 5v source.
The symptoms presently is a load that is always ON. ( I have checked the circuit for shorts/misconstructions 100 times). If i remove the MOC from the board. The load is still on. The load only switches off when the 330Ohm gate resistor is removed. however with this removed (and the MOC replaced) Applying the correct 5ma to drive the optocoupler does not ON the load. I have also tried removing the "snubber" portion (39Ohm,0.01uF Cap combination).
The Triac I am using is a T2512MH. Can anyone suggest debugging this issue?
