shimniok
Hi, all. I have a bit of a challenge for you -- one which I've so far utterly failed despite all my attempts -- is the mysterious Trio-Kenwood MTM-5010 MPU in my oscilloscope by any chance a well-known device under a different guise? The story behind this? well...
My BK Precision 1590A started behaving oddly. The scope has buttons instead of switches to select mode, timebase, trigger. (I knew I'd one day regret this "new fangled" technology
-- I want my Hitachi V1050F back, dangit)
For example, when you press the SINGLE trigger button, it selects X-Y timebase. If you press the A timebase button, it selects QUAD mode. DUAL timebase selects ALT timebase and ADD selects CH1. That's what I mean by odd. It struck me as a logic problem and after looking at the schematic, I see that all the buttons are set in a keyboard matrix and all the problem buttons correspond to two lines in that matrix which in turn connect to two MPU pins. The MPU is capturing the button press, but mis-reading its source (A and QUAD share the same matrix line).
I was curious to find info about this MPU, labelled Trio-Kenwood / MTM-5010 / 8851 294M / 8422 Z03. The parts list shows "MTM-5010". I've uploaded a detail portion of the schematic. Does it by any chance look familiar?
Usually I'm much better at digging up info like this and wouldn't have to ask. I've searched the web for a number of relevant keywords associated with the problem, the MPU, the scope, etc. I've reviewed datasheets for some of the well known CPUs/MPUs with which I'm only vaguely familiar (6502, 68xx, etc), I've searched for subsets of the pin names (EXTAL, XTAL, IRQ, STBY, SC/TO, TC) and I've searched for the numbers on the IC in hopes of finding any correlation but I'm coming up with nothing. Not even a hint.
The MPU looks relatively generic to me. It's a 0.6" 42-DIP package. Four GPIO ports (K[0..3], R[0..14], O[0..7], P[0..3]), some control lines, power.
While it'd be swell to replace the MPU with its equivalent, I think the reality is that I'll need to replace it with a modern MCU. The MPU, along with button polling duties, drives LEDs through transistor arrays (AN90B20), and controls the vertical and horizontal boards through, based on a quick review, TTL logic. If I can prove to myself that it's all logic level, then I can start developing the circuitry and software. Because, hey, I don't have enough projects to work on so why not add this to the list?![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Thanks, all.
Michael
Thanks, all.
Michael
